white(
The white( function returns white as a Panorama color value (see Colors).
Returns returns white as a Panorama color value (see Colors).
rgbstr(white()) ☞ 65535,65535,65535
htmlrgbstr(white()) ☞ FFFFFF
See Colors for more information about working with colors in Panorama formulas.
rgb(65535,65535,65535)
- alpha( -- extracts the alpha (opacity) from a color.
- black( -- returns black as a Panorama color value (see Colors).
- blue( -- extracts the blue intensity from a color.
- brightness( -- extracts the brightness from a color.
- getwebcolor( -- calculates an RGB color from a Netscape style web color.
- gray( -- returns a shade of gray as a Panorama color value (see Colors).
- green( -- extracts the green intensity from a color.
- hsb( -- creates a color by combining hue, saturation, and brightness components. See Colors.
- htmlrgb( -- converts text formatted as an HTML color into a Panorama color value (see Colors).
- htmlrgbstr( -- converts a color to text formatted as an HTML color.
- hue( -- extracts the hue from a color.
- info("colornames") -- returns a list of color names that can be used as a text object background and with the htmlcolor( function.
- info("formcolor") -- returns the background color of the current form.
- red( -- extracts the red intensity from a color.
- rgb( -- creates a color by combining red, green, and blue primary colors. See Colors.
- rgbstr( -- converts a color into text in the format *red,green,blue*.
- saturation( -- extracts the saturation from a color.
