rgbstr(
COLOR
The rgbstr( function converts a color into text in the format red,green,blue.
color – is the color you want to convert to text. This must either be a binary value created with the rgb(, hsb(, or other color generation functions, or must be an HTML color specification like "FF0000 (red) or "0000FF (blue). See Colors for more information.
Converts a color into text in the format red,green,blue. Each color value may be from 0 (completely dark) to 65535 (maximum brightness).
rgbstr(rgb(123,456,789)) ☞ 123,456,789
rgbstr(hsb(0,20000,1000)) ☞ 1000,695,695
rgbstr("CCFF33") ☞ 52428,65535,13107
See Colors for more information about working with colors in Panorama formulas.
str(red(thecolor))+","+str(green(thecolor))+","+str(blue(thecolor))
10.0No changeCarried over from Panorama 6.0.
