htmlrgbstr(
COLOR
The htmlrgbstr( function converts a color to text formatted as an HTML color.
color – is the color you want to convert to text. This must either be a binary value created with the rgb(, hsb(, or other color generation functions, or must be an HTML color specification like "FF0000"
(red) or "0000FF"
(blue). See Colors for more information.
Converts a color to text formatted as an HTML color.
htmlrgbstr(rgb(48000,24000,65000)) ☞ BB5DFD
htmlrgbstr(hsb(0,20000,10000)) ☞ 271B1B
See Colors for more information about working with colors in Panorama formulas.
radixstr("hex",red(thecolor))[-4,-3]+radixstr("hex",green(thecolor))[-4,-3]+radixstr("hex",blue(thecolor))[-4,-3]
- alpha( -- extracts the alpha (opacity) from a color.
- black( -- returns black as a Panorama color value (see Colors).
- blue( -- extracts the blue intensity from a color.
- brightness( -- extracts the brightness from a color.
- getwebcolor( -- calculates an RGB color from a Netscape style web color.
- gray( -- returns a shade of gray as a Panorama color value (see Colors).
- green( -- extracts the green intensity from a color.
- hsb( -- creates a color by combining hue, saturation, and brightness components. See Colors.
- htmlrgb( -- converts text formatted as an HTML color into a Panorama color value (see Colors).
- hue( -- extracts the hue from a color.
- info("colornames") -- returns a list of color names that can be used as a text object background and with the htmlcolor( function.
- info("formcolor") -- returns the background color of the current form.
- red( -- extracts the red intensity from a color.
- rgb( -- creates a color by combining red, green, and blue primary colors. See Colors.
- rgbstr( -- converts a color into text in the format *red,green,blue*.
- saturation( -- extracts the saturation from a color.
- white( -- returns white as a Panorama color value (see Colors).
