htmlrgb(
HTMLCOLOR
The htmlrgb( function converts text formatted as an HTML color into a Panorama color value (see Colors).
htmlcolor – is six hexadecimal digits specifying the color (2 digits for red, 2 for blue, 2 for green).
Converts text formatted as an HTML color (for example FFFFFF
for white) into a color.
rgbstr(htmlrgb("FFFFFF")) ☞ 65280,65280,65280
rgbstr(htmlrgb("3333FF")) ☞ 13107,13107,65535
Note: This function is included for compatibility with Panorama 6 and earlier, however, it is no longer necessary. You can now simply use six hex digits wherever a color value is called for.
rgbstr("3333FF") ☞ 13107,13107,65535
See Colors for more information about working with colors in Panorama formulas.
rgb(radix("hex",thetext[1;2]+"00"),radix("hex",thetext[3;2]+"00"),radix("hex",thetext[5;2]+"00"))
- alpha( -- extracts the alpha (opacity) from a color.
- black( -- returns black as a Panorama color value (see Colors).
- blue( -- extracts the blue intensity from a color.
- brightness( -- extracts the brightness from a color.
- getwebcolor( -- calculates an RGB color from a Netscape style web color.
- gray( -- returns a shade of gray as a Panorama color value (see Colors).
- green( -- extracts the green intensity from a color.
- hsb( -- creates a color by combining hue, saturation, and brightness components. See Colors.
- htmlrgbstr( -- converts a color to text formatted as an HTML color.
- hue( -- extracts the hue from a color.
- info("colornames") -- returns a list of color names that can be used as a text object background and with the htmlcolor( function.
- info("formcolor") -- returns the background color of the current form.
- red( -- extracts the red intensity from a color.
- rgb( -- creates a color by combining red, green, and blue primary colors. See Colors.
- rgbstr( -- converts a color into text in the format *red,green,blue*.
- saturation( -- extracts the saturation from a color.
- white( -- returns white as a Panorama color value (see Colors).
