alpha(
COLOR
The alpha( function extracts the alpha (opacity) from a color.
color – is the color you want to extract information from. This must either be a binary value created with the rgb(, hsb(, or other color generation functions, or must be an HTML color specification like "FF0000
(red) or "0000FF
(blue). See Colors for more information.
This function extracts the alpha (opacity) from a color.
The example below calculates the opacity of the color (in percent, from 0 to 100%).
Opacity = alpha(HighlightColor)* 100 / 65535
For more examples of color, see Colors.
- black( -- returns black as a Panorama color value (see Colors).
- blue( -- extracts the blue intensity from a color.
- brightness( -- extracts the brightness from a color.
- getwebcolor( -- calculates an RGB color from a Netscape style web color.
- gray( -- returns a shade of gray as a Panorama color value (see Colors).
- green( -- extracts the green intensity from a color.
- hsb( -- creates a color by combining hue, saturation, and brightness components. See Colors.
- htmlrgb( -- converts text formatted as an HTML color into a Panorama color value (see Colors).
- htmlrgbstr( -- converts a color to text formatted as an HTML color.
- hue( -- extracts the hue from a color.
- info("colornames") -- returns a list of color names that can be used as a text object background and with the htmlcolor( function.
- info("formcolor") -- returns the background color of the current form.
- red( -- extracts the red intensity from a color.
- rgb( -- creates a color by combining red, green, and blue primary colors. See Colors.
- rgbstr( -- converts a color into text in the format *red,green,blue*.
- saturation( -- extracts the saturation from a color.
- white( -- returns white as a Panorama color value (see Colors).
10.0 | New | New in this version |
