croptext(
text
length
The croptext( function crops text to a specified length. If the text was already shorter than the specified length, it is left unchanged. If it is longer, the text is cut off and an ellipsis is added on the end.
text – the original text.
length – maximum length of the text
This function crops text to a specified length. If the text was already shorter than the specified length, it is left unchanged. If it is longer, the text is cut off and an ellipsis is added on the end.
croptext("abc",4) ☞ abc
croptext("abcd",4) ☞ abcd
croptext("abcde",4) ☞ abc…
Notice that the maximum length of the output is the specified length, including the ellipsis if the text is longer than the specified length.
- regexreplacefirst( -- replaces the first occurrence of a regular expression pattern with new text.
- regexreplacefirstexact( -- replaces the first occurrence of a regular expression pattern with new text.
- replacefirst( -- replaces the first occurence of some text with new text.
