newdatabasewithtemplate
DEFAULTTEMPLATE
The newdatabasewithtemplate statement creates a new database with a template.
defaulttemplate – default template, can be either actual tags or name of common template.
This statement creates a new database with a template. The user gets a chance to edit the template before the fields are actually created. One option is to specify one of the pre-built templates that are available (see ConstructFieldsSheet).
newdatabasewithtemplate "Mailing List"
You can also use the actual field definitions:
newdatabasewithtemplate "Address
City
State
Zip"
This statement is used internally by Panorama.
- automaticfieldname( -- returns an available field name.
- Field Blueprint Dialog -- examining and modifying the raw specification of a field.
- fieldalignment( -- returns the alignment of a database field.
- fieldformula( -- returns the formula associated with a database field.
- fieldnumber( -- returns the number of a database field (starting with 1).
- fieldpattern( -- returns the output pattern associated with a database field.
- fieldtypes( -- returns a carriage return delimited array with a list of the fields and field data types.
- fieldwidth( -- returns the width (in the data sheet) of a database field.
- hiddenfields( -- returns a list of hidden fields in the curent data sheet window
- visiblefieldnumbers( -- returns a data array of visible fields (by number) in the data sheet.
- visiblefields( -- returns a list of visible fields in the data sheet.
