The primary method for modifying the properties of a field is using the Field Properties Panel, which slides in from the right edge of the data sheet.
To show or hide this panel, simply click the Properties tool in the upper right corner of the window. (You can also choose Show Field Properties from the Field menu.)
When the Field Properties Panel is open, it displays all the attributes of the currently selected field. You can leave the panel open and click on different fields to see the properties associated with each field.
The Field Properties Panel is also used to modify a field’s properties. In this example, the panel is being used to change the display alignment of the data within a field.
Like any other operation, changes made to field properties can be reversed with the Undo command. For example, suppose I accidentally change the PayTo field to Numeric. This doesn’t work correctly, since the data doesn’t contain numbers. To get the original data back, simply choose Undo from the Edit menu. Remember, you are not limited to just one Undo, you can undo multiple recent changes.
To learn about individual field properties see Field Properties. You can also view and modify field properties with the Field Blueprint Dialog.
- automaticfieldname( -- returns an available field name.
- Field Blueprint Dialog -- examining and modifying the raw specification of a field.
- fieldalignment( -- returns the alignment of a database field.
- fieldformula( -- returns the formula associated with a database field.
- fieldnumber( -- returns the number of a database field (starting with 1).
- fieldpattern( -- returns the output pattern associated with a database field.
- fieldtypes( -- returns a carriage return delimited array with a list of the fields and field data types.
- fieldwidth( -- returns the width (in the data sheet) of a database field.
- hiddenfields( -- returns a list of hidden fields in the curent data sheet window
- visiblefieldnumbers( -- returns a data array of visible fields (by number) in the data sheet.
- visiblefields( -- returns a list of visible fields in the data sheet.
