saveblueprint
DATABASE
PATH
The saveblueprint statement save a blueprint of a database’s structure.
database – database to save.
path – path where the blueprint should be saved. If this is blank, or omitted, the blueprint will be saved in the same folder as the database, using the database name with .panblueprints appended.
Panorama’s blueprint feature allows the structure of a database (its fields, forms, procedures and preferences) to be exported in a pure text format. Every detail of the database design is included in the blueprint. The text of a blueprint is actually a Panorama program that when run, will create an exact clone of the original database (without any data). Blueprints have several uses:
It’s easy to create a blueprint of the current database. This example will create a blueprint in the same folder as the database, with the same name as the current database but with an extension of .panblueprint. For example, if the database is named Mailing List, the blueprint file will be Mailing List.panblueprint.
saveblueprint ""
If you want to create a blueprint for some other open database, simply supply the database name.
saveblueprint "Checkbook"
Blueprints are normally saved in the same folder as the database, with the same name, but you can specify a different folder and/or name. This example makes a blueprint of the Contacts database. The blueprint will be named Mailing List.panblueprint and will be saved into the Dropbox folder.
saveblueprint "Contacts","~/Dropbox/Mailing List"
If you later want to convert a blueprint back into a new, cloned database, use the newdatabaseusingblueprint statement.
newdatabaseusingblueprint "~/Dropbox/Mailing List"
You can also clone a single form from a blueprint using the newformusingblueprint statement.
Note: Panorama’s blueprint files are not monolithic text files, but rather a package that contains multiple text files. The Finder allows you to see the contents of the blueprint file by right clicking and choosing Show Package Contents from the pop-up menu. The package contains a master text file (Database Blueprint) that contains the specifications for all database fields, permanent variables, and preferences, and also determines the order of forms and procedures within the database. The package contains a Forms folder that contains a separate text blueprint for each form in the database. There is also a Procedures folder that contains individual files with the source code for each procedure.
All of the files in the package have an extension of “.estes” and can be opened with any text editor.
