appledayzero(
The appledayzero( function returns an internal constant used for converting between superdates and regular dates.
This function returns an internal constant used for converting between superdates and regular dates. You should not use this function directly, instead use the superdate( and regulardate( functions.
- calendardate( -- helps in creating monthly calendars.
- calendarday( -- helps in creating monthly calendars.
- datevalue( -- converts integer values for year, month and day into a number representing a date.
- dayofmonth( -- computes the day within a month.
- dayofquarter( -- computes the day within a quarter.
- dayofweek( -- computes the day of the week, with Sunday being 0, Monday 1, etc.
- dayofyear( -- computes the day within a quarter.
- dayvalue( -- extracts the day from a date as a numeric value.
- firstdayofweek( -- returns the user's preference for first day of the week.
- month1st( -- computes the first day of a month.
- monthlength( -- computes the length (number of days) of a month.
- monthmath( -- takes a date and computes the date that is one or more months before or after the original date.
- monthvalue( -- extracts the month from a date as a numeric value.
- quarter1st( -- computes the first day of a quarter.
- quartervalue( -- extracts the quarter from a date as a numeric value.
- regulardate( -- extracts a regular date (number of days from January 1, 4713 B.C.) from a superdate.
- today( -- returns a number corresponding to today's date.
- week1st( -- computes the first day of a week (Sunday).
- weekvalue( -- extracts the week from a date as a numeric value.
- year1st( -- computes the first day of a year.
- yearvalue( -- extracts the year from a date as a numeric value.
| 10.0 | New | New in this version |
