The tagnumber( function checks to see if a specified position is inside of a tag (usually an HTML tag).
This function has four parameters:text – is the item of text that contains the tag you want to locate.
header – is the text that you want to use as a tag header. For example, if you want to locate an HTML tag, use "<"
as the header. If you wanted to locate a bold text item you would use "<B>"
as the header. (Note: Upper or lower case is ignored, so "<b>"
will also work.)
trailer – the text that you want to use as a tag trailer. For example, if you want to locate an HTML tag, use ">"
as the trailer. If you wanted to locate a bold text item you would use "</B>"
as the trailer. (Note: Upper or lower case is ignored, so "</b>"
will also work.)
position – is the position within the text parameter
The tagnumber( function checks to see if a specified position is inside of a tag (usually an HTML tag). The function returns the tag number (1, 2, 3, etc.) or 0 if the position is not within any specified tag.
This example assumes you have a field or variable named myPage that contains an HTML page that is being edited with a Text Editor Object. The example will check the currently selected text to see if it is inside a tag. If it is, the body of that tag will be selected.
local tStart,tEnd,clickStart,clickEnd,thetag
activesuperobject "getselection",clickStart,clickEnd
thetag=tagnumber(Page,"<",">",clickStart)
if thetag>0
tStart=tagstart(myPage,"<title>","</title>",1)
if tStart=0
rtn
tEnd=tagend(myPage,"<title>","</title>",1)
activesuperobject "setselection",tStart-1,tEnd-1
