tagparameter(
TEXT
TAG
ITEM
The tagparameter( function extracts the value of a tag parameter embedded in some text, where the tag parameter takes the form name=value.
text – is the item of text that contains the data you want to extract.
tag – is the name of the tag parameter you want to extract, including the trailing = sign (you may use other terminators, for example colons (font:Helvetica) or period (font.Helvetica). For example, if you want to extract the font name from the text font=Helvetica size=12 the tag would be font=.
item – is the number of the parameter you want to extract. This is usually 1, but may be other values if you expect multiple instances of the parameter (multiple fonts, for example). It will default to one if this parameter is omitted.
The tagparameter( function extracts the value of a tag parameter embedded in some text, where each tag parameter takes the form name=value. This function returns the contents (text) of the specified parameter. If the parameter is surrounded by quotes, the quotes are removed. (Quotes are necessary if the parameter value contains spaces, for example font="Times Roman". Allowed quote characters include double quotes ("), single quotes ('), single and double smart quotes (“” ‘’), curly brackets ({}) and multiple pipe characters (|).
This example very quickly builds a list of all the GIF and JPEG images displayed in the page HTMLPage.
local imageTags,imageNames
imageTag=tagarray(HTMLPage,"<IMG",">",cr())
arrayfilter imageTag,imageNames,cr(),tagparameter( import(), "src=",1)
10.0UpdatedCarried over from Panorama 6.0, but now allows the item parameter to be omitted (it will default to 1).
