Values are the raw material that formulas work with — numbers and text. A value may be embedded in the formula itself (see Constants), may be stored in a database field (see Fields) or may be stored in a variable (see Variables).
- Arithmetic Formulas -- mathematical operators and functions.
- Characters and Unicode Values -- working with individual characters of text.
- Constants -- values embedded into a formula.
- Date Arithmetic Formulas -- performing calculations on dates, and converting between dates and text.
- Formula Workshop -- formula workshop wizard for testing and experimenting with formulas.
- formulafields( -- returns a list of fields used in a formula.
- formulaidentfiers( -- returns a list of identifiers (fields and variables) used in a formula.
- Formulas -- basics of formulas: components and grammar.
- formulavariables( -- returns a list of variables used in a formula.
- Functions -- index of all functions available for use in Panorama formulas.
- Linking with Another Database -- techniques for relating multiple database files so that they work together.
- Non Decimal Numbers -- working with numbers in alternative (non-decimal) bases, including binary, octal and hexadecimal.
- Numbers -- Working with numeric values in a formula, and converting between numbers and text.
- Operators -- index of all operators available for use in Panorama formulas.
- Quotes -- text constants embedded into a formula
- Recompiling Code -- recompiling code & formulas
- Statements -- index of all statements available for use in Panorama procedures.
- SuperDates -- date and time combined into a single value.
- Tag Parsing -- Panorama functions for working with text that contains data delimited by tags, including HTML.
- Text Formulas -- manipulating text with a formula (concatenation, extraction, rearranging, etc.)
- Time Arithmetic Formulas -- performing calculations on times, and converting between times and text.
- True/False Formulas -- logical boolean calculations.
- Using Fields in a Formula -- accessing database fields within a formula.
- Variables -- storing and retrieving individual items of data, not part of a database.
