The formulafields( function returns a list of fields used in a formula.
This function has two parameters:database – the database the formula is associated with. If this is omitted or is ""
, the current database is assumed.
formula – is the formula to be analyzed. If the formula is specified inline in the function itself, it must be quoted (see Quotes). Otherwise, you can pre-store the formula in a field or variable.
The function returns a list of fields used in a formula. The list is returned as a carriage return delimited text array.
For example,
formulafields({alpha+cr()+bravo+sqr(Price)+upper(Name)})
will return the two fields that appear in this formula:
Price
Name
If the formula is associated with a different database (not the current database), you must explictly specify the database, like this.
formulafields("Mailing List",{alpha+cr()+bravo+sqr(Price)+upper(Name)})
10.2 | New | Carried over from Panorama 6.0 |
