Occasionally you may want to completely remove the raw data, leaving only the summary information.
This will remove all of the data records. The level 1 summaries (in this case Category) will be turned into data records. Level 2 summaries will be turned into Level 1, etc. In other words, everything shifts down a level.
Be very careful with this operation — it deletes all of the data in the database! Usually you’ll want to perform this operation on a copy. Of course if you realize you’ve done this by mistake you can Undo, but other than that, the data is gone once you’ve removed it.
10.0UpdatedCarried over from Panorama 6.0, but is now done from a menu instead of a dialog.
