yoke(
PREFIX
JOINER
SUFFIX
The yoke( function appends two text items together, with a joiner between them if both are non-blank.
prefix – first text item.
joiner – joiner that will be placed between if both prefix and suffix are non-blank.
suffix – second text item.
This function appends two text items (prefix and suffix) together. If both are non-blank, a joiner is placed in between. If either (or both) is blank, the joiner is not used. In some ways this is the reverse of the sandwich( function.
yoke("this"," and ","that") ☞ this and that
yoke("this"," and ","") ☞ this
yoke(""," and ","that") ☞ that
yoke(""," and ","") ☞
?(prefix<>"" and suffix<>"",prefix+joiner+suffix,prefix+suffix)
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- tab( -- generates a tab.
