The jsonimport( function converts JSON into a Panorama dictionary or data array.
This function has one parameter:json – The JSON text to be imported.
This function converts JSON into a Panorama dictionary or data array. (JSON is a data interchange format that is used by many web APIs. See http://json.org for more information.)
For example, this formula creates a Panorama dictionary.
jsonimport(||| {"Name" : "Jack", "Color" : "Blue", "Size" : 38} |||)
The example above is exactly equivalent to this formula that uses the initializedictionary( function.
initializedictionary("Name","Jack","Color","Blue","Size",38)
This example creates a Panorama data array.
jsonimport(|||["Orange", "Teal", "Yellow"]|||)
The example above is exactly equivalent to this formula that uses the dataarray( function.
dataarray("Orange", "Teal", "Yellow")
Complex JSON text can include arrays nested within dictionaries, or vice versa. The jsonimport( function will create the equivalent nested structure using Panorama dictionaries and data arrays. You can use the getstructurevalue( function to extract specific items from this sort of nested structure.
The JSON format allows a data value to be unspecified, this is called a null value. This example includes a null color value.
jsonimport(||| {"Name" : "Jack", "Color" : null, "Size" : 38} |||)
Panorama does not normally allow null data, so when the jsonimport( function encounters a null value in the JSON text, the function places an error value in the result dictionary (if using Panorama X 10.2 or later).
For example, suppose you have a database with fields for Name, Color and Size, and you wish to copy JSON data into these fields. This code will check to see if the color is null, and if so, prompt the user to enter a color.
let data = jsonimport(||| {"Name" : "Jack", "Color" : null, "Size" : 38} |||)
Name = getdictionaryvalue(data,"Name")
Color = getdictionaryvalue(data,"Color")
if error
gettext Color,"Prompt","Please specify a color.",
"Subprompt","(no color specified in JSON data)",
"Button","Ok","AbortButton","Cancel"
if info("dialogtrigger")="Cancel" rtn endif
Size = getdictionaryvalue(data,"Size")
Another approach would be to use the catcherror( function to provide a default value in case the JSON includes a null value, like this:
Name = catcherror("",getdictionaryvalue(data,"Name"))
Color = catcherror("white",getdictionaryvalue(data,"Color"))
Size = catcherror(36,getdictionaryvalue(data,"Size"))
Unlike the previous example, this code will work with a null value in any position of the JSON data.
10.2 | Updated | This function now works with null values in the JSON data. |
