relatedrecordid(
SOURCEDATABASE
The relatedrecordid( function returns the record id of a record in a related database that matches the current record in the current database based on a relational specification.
sourcedatabase – is the name of the source database. This database must be open.
This function returns the record id of a record in a related database that matches the current record in the current database based on a relational specification (a relational specification is based on one or more key fields or formulas in each database, see Relational Database Management).
This example uses the releatedrecordid( function and the findid statement to find the customer record associated with the current customer in the current database (for example an order entry database).
let id = relatedrecordid("Customer List")
if error
message "Customer not found"
return
topwindow "Customer List"
findid id
- addrelatedrecord -- adds a new record to the related database corresponding to the current database.
- findrelated -- finds information that matches the current record in a related database.
- Join Databases -- joining another database into the current database (relational join).
- Linking with Another Database -- techniques for relating multiple database files so that they work together.
- posttorelated -- posts data in the current record to the corresponding record in a related database.
- related( -- searches a database for a record in a related database that matches the current record in the current database based a relational specification (based on one or more key fields or formulas in each database), then uses a formula to return other information from the same record. This is similar to the lookup( function, but instead of using an individual field for the key, a relation is used (see Relational Database Management).
- relatedarray( -- builds an Text Array by scanning a database and creating an array element for every record that matches a relational specification (based on one or more key fields or formulas). This is similar to the arraybuild( function, but instead of using an individual field for the key, a relation is used (see Relational Database Management).
- Relational Database Management -- linking together multiple databases based on common data.
- Relational Workshop -- tool that assists in composing relational lookup(, superlookup(, lookupall( and arraybuild( functions.
- selectrecordsrelatedto -- selects records in the current database that are related to any record in another database.
- selectrelated -- selects information that matches the current record in a related database.
