soundprogress(
IDENTIFIER
The soundprogress( function returns the progress of the played sound from 0 to 1.
identifier – identifier for the sound (sound must already be playing).
This function returns the progress of the played sound from 0 to 1. You could use this function in a timer (see starttimer) to display the playback progress with a Slider Object or a Progress Bar Object.
- info("sounds") -- returns a carriage return delimited list of all currently playing sounds.
- soundduration( -- returns the duration (in seconds) of the specified playing sound.
- sounddurationhhmmss( -- returns the duration (in hours:minutes:seconds) of the specified playing sound.
- soundplaying( -- returns true if the specified sound is currently playing, false if it is paused or not playing at all.
- soundposition( -- returns the current playback position (in seconds) of the specified playing sound.
- soundpositionhhmmss( -- returns the current playback position (in hours:minutes:seconds) of the specified playing sound.
- soundstatus( -- returns the status of the specified sound: stopped, playing or paused.
- soundvolume( -- returns the current volume of the specified playing sound.
