The emptycell( function returns true if the specified field is empty in the current record.
This function has one parameter:field – name of the field to test.
This function returns true if the specified field is empty in the current record. It doesn’t matter what type of data is in the field – text, numbers, dates or binary data.
emptycell("Quantity") ☞ -1
For example you could select all records where the Date field is empty.
select emptycell("Date")=true()
