formxy
VERTICAL
HORIZONTAL
The formxy statement programmatically scrolls a form to a new position.
This statement has two  parameters:
vertical – the vertical distance (in points) you wish to move the form in its window (72 points = 1 inch), measured from the top edge of the form.
horizontal – the horizontal distance (in points) you wish to move the form in its window (72 points = 1 inch), measured from the left edge of the form.
This statement allows you to perform the same task as manually adjusting the vertical or horizontal scroll bars of any active form window; even if the scroll bars are not available for that form’s window.
This example opens a form called List View 1 and scrolls the window down four inches from the top of the form.
openform "List View 1"
formxy 4*72,0
- info("activeobject") -- returns the name of the currently active text editor or word processor object (if any).
- info("scrollpoint") -- returns the distance the current form is scrolled horizontally and vertically.
- objectinfo( -- returns information about a graphic object: its location, size, color, font, etc.
- objectinfoarray( -- builds a text array of form object properties
- Web Browser Programming -- programming a Web Browser Object (including JavaScript).
