info("focusobject")
The info(“focusobject”) function returns the name of the currently active text editor or word processor object, if any.
This function returns the name of the currently active text editor or word processor object, if any. If no such object is currently being edited, the function returns empty text (""
This example inserts the current date and time into whatever text editor object is currently being edited. This function will work with both Text Editor and Word Processor objects. The first line of the procedure checks to make sure that something is really being edited at this time).
if info("focusobject")<>""
activeobjectaction "InsertText",
datepattern( today(),"mm/dd/yy")+"@"+
timepattern( now(),"hh:mm am/pm")
Note: In Panorama 6 and earlier, this function was called info(“activesuperobject”). The info(“activesuperobject”) function is still available for compatibility with legacy databases.
- info("activeobject") -- returns the name of the currently active text editor or word processor object (if any).
- info("scrollpoint") -- returns the distance the current form is scrolled horizontally and vertically.
- objectinfo( -- returns information about a graphic object: its location, size, color, font, etc.
- objectinfoarray( -- builds a text array of form object properties
- Web Browser Programming -- programming a Web Browser Object (including JavaScript).
10.0 | New | New in this version (however, it duplicates the functionality of the existing info("activesuperobject") function. |
