labelizepattern(
LABEL
VALUE
PATTERN
The labelizepattern( function formats a text value using a label and a pattern.
label – is a label identifying the value.
value – is the value to be formatted.
pattern – is the pattern that will be used. If this parameter is omitted, a default pattern will be used (see below).
This function formats a text value using a label and a pattern. It is used internally to create functions like labelizeformula( and labelizeinfo(, but can also be used independently. In its simplest form, this function takes a label and a value, and combines them using a default pattern.
labelizepattern("Sum",2+2) ☞ Sum: 4
labelizepattern("Database",info("databasename")) ☞ Database: Contacts
labelizepattern("NAME",upper(Name) ☞ NAME: BOB WILSON
If the value contains more than one line, a different default pattern is used. Suppose you have a field named Full Address that contains an entire address. In that situation, the formula:
labelizepattern("OPEN DATABASES",info("files"))
will return a result like this:
=== OPEN DATABASES ============
Contacts
Orders
Products
=== END OF OPEN DATABASES ============
Custom Patterns
If the standard pattern doesn’t meet your needs, you can add a third parameter to supply your own custom pattern. This pattern must contain «label»
where you want the label to appear, and «value»
where you want the value to appear. Here’s an example where using a custom pattern reveals that the city name has an extra space on the end.
labelizepattern("City",upper(City),"«label» >>>«value»<<<") ☞ City >>>FRESNO <<<
This is such a common situation that there is a special shortcut pattern set up for this situation, ><
labelizepattern("City",upper(City),"><") ☞ City -->FRESNO <--
Note: The default patterns built into the labelizepattern( function are:
"«label»: «value»"
and
"=== «label» ============"+cr()+"«value»"+cr()+"=== END OF «label» ============"
for multi-line values.
- Coding with Debug Instrumentation -- modifying your code to generate debug instrumentation output.
- Crash Proof Debug Instrumentation Monitoring -- real time crash-proof instrumentation monitoring
- Customizing Debug Instrumentation Coverage -- specifying what code is being debugged at the moment.
- Debug Instrumentation -- conditional logging of the internal state of Panorama program code.
- Debug Instrumentation Log Window -- dynamically monitor debug instrumentation output as your program runs.
- Debug Instrumentation Monitoring using an External Program -- monitoring debug instrumentation with an external program (Terminal.app, BBEdit.app).
- Debug Instrumentation Text File -- configuring and accessing the debug instrumentation log (text) file.
- info("runningunderterminal") -- returns the name of the terminal program if Panorama was launched under one, otherwise it returns empty text.
- Recording Code Triggers in Debug Instrumentation -- the code triggers option automatically tracks whenever any code is triggered, whether from a menu, a button, or implicitly (for example when data is entered).
- Recording Control Flow in Debug Instrumentation -- configure debug instrumentation to automatically log when control flow is non-linear, for example a call, return, goto, etc.
- setzlog -- turns instrumentation coverage on or off for a specific procedure (or all procedures within a database).
- zlog -- outputs a message to the instrumentation log (if instrumentation is enabled).
- zlogalways -- unconditionally outputs a message to the instrumentation log.
- zlogcoverage -- allows instrumentation coverage to be turned on or off within a procedure.
- zlogdictionary -- outputs a data dictionary to the instrumentation log (if instrumentation is enabled).
- zlogging( -- returns true if zlogging is enabled for the current database and procedure, otherwise false.
