kcdiff(
IN
OUT
The kcdiff( function calculates the number of frames between two frames of 35mm film, using inclusive counts (submitted by chris watts)
in – starting frame expressed as a text value in the format feet+frames
out – ending frame expressed as a text value in the format feet+frames
Calculates the number of frames between two frames of 35mm film, using inclusive counts (Submitted by Chris Watts)
kcdiff("1234+12","1234+12") ☞ 1
kcframes(out)-kcframes(in)+1
