kcadd(
KEYCODE
OFFSET
The kcadd( function takes a keycode for 35mm film and adds a number of frames to it and returns a keycode as a string.
keycode – starting frame expressed as a text value in the format feet+frames
offset – integer value (number of frames to offset).
Takes a keycode for 35mm film and adds a number of frames to it and returns a keycode as a string. (Submitted by Chris Watts)
kcadd("1234+12",-1) ☞ 1234+11
feetandframes(kcframes(keycode)+offset)
