scripttimeout
MAXRUNTIME
The scripttimeout statement sets the maximum runtime allowed for an embedded program (AppleScript, ShellScript, Perl, Ruby or Python).
maxruntime – Maximum script runtime (in seconds)
This statement sets the maximum runtime allowed for an embedded program (AppleScript, ShellScript, Perl, Ruby or Python).
scripttimeout 600
applescript |||some very long running script|||
If the timeout value is never set, the default is 60 seconds. The value set by the scripttimeout statement can be overriden on a case-by-case basis by the timeout parameter of the AppleScript, ShellScript, Perl, Ruby and Python statements.
- applescript -- executes an AppleScript.
- applescript( -- executes AppleScript source code and returns the result.
- blindposixscript( -- executes a POSIX shell script using NSTask and returns the process id.
- executeapplescript -- compiles and runs an AppleScript.
- executeperlscript -- executes Perl code.
- executesudounix -- executes a UNIX shell command using *sudo* (root) privileges.
- executeunix -- executes a UNIX shell command.
- perl -- executes a Perl script (program).
- perl( -- executes a perl program and returns the result (stdout).
- php -- executes a PHP script (program).
- php( -- executes a PHP program and returns the result.
- posixscript( -- executes a POSIX shell script using NSTask and returns the result.
- posixtask( -- executes a POSIX shell script in the background using NSTask.
- python -- executes a Python script (program).
- python( -- executes a python program and returns the result (stdout).
- ruby -- executes a Ruby script (program).
- ruby( -- executes a ruby program and returns the result (stdout).
- scriptbglog -- specifies a path/file for output from STDOUT from embedded programs run in the background (Perl, Ruby, Python, PHP).
- Scripting Language Configuration -- configuring the scripting languages available to Panorama (Perl, PHP, Python and Ruby).
- shellscript -- executes a UNIX shell script.
- shellscript( -- executes a UNIX shell script and returns the result.
- usebashprofile -- grabs the search path from the `.Bash_profile` file in the user's home folder, so that these paths will be used by scripting languages (*Ruby, Python*, etc.).
- xcallbackurl -- performs an action in another application using the x-callback-url mechanism.
