revealinfinder
PATH
The revealinfinder statement reveals a file or folder in the Finder.
path – is a path to the file or folder to be revealed, including the file or folder name (see Files and Folders for more information about file paths).
This statement reveals a document or application in the Finder. A new Finder window opens displaying the specified item, with the specified item highlighted. This example will reveal the PDF document concert-ticket.pdf in the Finder
revealinfinder "~/downloads/concert-ticket.pdf"
If you want to reveal multiple items, use the revealmultipleinfinder statement.
Legacy Two-parameter Syntax
Previous versions of Panorama (version 6 and before) used a two-parameter format for the revealinfinder statement:
revealinfinder folder,filename
For compatibility with existing databases, this format still works. Here is an example that reveals an image that is in a subfolder of the folder that contains the current database.
revealinfinder dbsubfolder("Images"),"someimage.png"
- applescriptconstant( -- converts an expression into an AppleScript literal.
- javascriptconstant( -- converts an expression into a JavaScript literal.
- javascriptstring( -- converts a text string into a JavaScript string
- perlconstant( -- encodes text for use as a constant in a Perl program.
- phpconstant( -- encodes text for use as a contant in a php program.
- pythonconstant( -- encodes text for use as a constant in a python program.
- Reveal in Finder -- reveal the location of a database in the Finder.
- rubyconstant( -- encodes a value for use as a constant in a Ruby program.
- runningappinfo( -- returns information about applications that are currently running on this computer.
- Scripting Panorama X with AppleScript -- embedding Panorama code into AppleScript (allowing Panorama to be controlled from other programs).
- unixshellstring( -- encodes text for use as a parameter to a unix shell command.
10.0 | Updated | Carried over from Panorama 6.0 but now uses a one parameter syntax. (The old two parameter syntax is still available.) |
