formulamerge
TEMPLATE
RESULT
The formulamerge statement merges data into a template.
template – Text of template.
result – Output text (each formula has been replaced by its value).
This statement merges data into a template. Within the template you can place formulas inside { and } characters.
This example assumes that the database has fields named Name, City and State (or that there are variables with these names).
local Letter
formulamerge "Dear {Name},"+cr()+cr()+
    "I am planning a visit to you in {sandwich("",City,", ")+State} next week.",Letter
The end result will be in the Letter variable, and will look something like this:
Dear John Watson,
I am planning a visit to you in San Francisco, CA next week.
If there is an error in the template the result will be:
FormulaMerge Error “error message” Template “template”.
