executeasap
CODE
The executeasap statement executes the specified code at the first possible opportunity, non-atomically.
code – code to execute in the next run loop.
This statement executes the specified code at the first possible opportunity. The code will be executed non-atomically, so it is always allowed to display data changes, switch window configurations, and save datatabases.
Usually the only reason to use this statement is to allow atomic code to trigger non-atomic code (see Understanding the Run Loop). For example, suppose you want a dialog sheet to appear asking for a name every time a new record is added to a database. You can’t normally do this with the .NewRecord procedure, because that procedure is not allowed to open new windows with a statement like gettextdialog. But by using the executeasap statement, you can postpone the operation of the gettextdialog for a fraction of a second, until after Panorama has finished creating the new record. At that point it is safe to do whatever you want.
executeasap {gettextdialog Name,
"Prompt","Enter this person's name",
"Sheet","YES",
"Button","Enter","AbortButton","Cancel",
"Width",300}
Though the executeasap statement makes it safe to do whatever you want, we recommend that you think long and hard about whether you really want your database to work in this unusual way. If you need to use the executeasap statement to accomplish your task, you are probably creating a very non-standard user interface that probably goes against the best modern practices in UI design.
Also if you’re not careful, the executeasap statement could get you into an endless loop that can only be cut short by forcing Panorama to quit. For example, suppose you put the code above into an execute( formula in a text display object. Simply displaying the object would trigger the dialog, then closing the dialog would display the object again, opening the dialog again, ad infinitum. So look out for this situation.
- Custom Statements -- creating your own custom statements that can be used in your code.
- info("computername") -- returns the name of the computer (as set up in the System Preferences Sharing panel).
- parameterentity( -- returns the entity (field or variable) associated with a subroutine parameter, if any.
- Timer Workshop -- provides a tool for monitoring timers and testing timer configurations.
- timerexists( -- checks to see whether a timer exists.
- Timers -- executing recurring periodic background code at fixed intervals.
- Understanding the Run Loop -- explanation of how Panorama code interacts with the run loop to respond to mouse clicks, keyboard presses, display updates and other events that require attention.
- wait -- pauses the program for a specified period of time.
