labelizeformula(
FORMULA
PATTERN
The labelizeformula( function returns the value of a formula along with the formula itself as a label.
formula – is the text of the formula, which must be quoted.
pattern – is the pattern that will be used. If this parameter is omitted, a default pattern will be used (see below).
This function returns the value of a formula along with the formula itself as a label. This saves having to type the formula twice when you need to display a formula when logging and debugging, for example in a zlog statement. If you don’t specify a pattern, the output will be the formula (the label), followed by -->
, followed by the value calculated by the formula, as shown by these examples.
labelizeformula({2+2}) ☞ 2+2 --> 4
labelizeformula({info("databasename")}) ☞ info("databasename") --> Contacts
labelizeformula({upper("Name")}) ☞ upper("Name") --> ROBERT
If the formula result contains more than one line, a different default pattern is used. For example, the info(“files”) function will return a multiline list of open databases. So the formula:
labelizeformula({info("files")})
will return a result like this:
=== info("files") ============
Contacts
Orders
Products
=== END OF info("files") ============
Custom Patterns
If the standard pattern doesn’t meet your needs, you can add a second parameter to supply your own custom pattern. This pattern must contain «label»
where you want the label to appear, and «value»
where you want the value to appear. Here’s an example where using a custom pattern reveals that the city name has an extra space on the end.
labelizeformula({upper(City)},"«label» >>>«value»<<<") ☞ upper(City) >>>FRESNO <<<
This is such a common situation that there is a special shortcut pattern set up for this situation, ><
labelizeformula({upper(City)},"><") ☞ upper(City) -->FRESNO <--
Note: The default patterns built into the labelizeformula( function are:
"«label» --> «value»"
and
"=== «label» ============"+cr()+"«value»"+cr()+"=== END OF «label» ============"
for multi-line values.
- Coding with Debug Instrumentation -- modifying your code to generate debug instrumentation output.
- Crash Proof Debug Instrumentation Monitoring -- real time crash-proof instrumentation monitoring
- Customizing Debug Instrumentation Coverage -- specifying what code is being debugged at the moment.
- Debug Instrumentation -- conditional logging of the internal state of Panorama program code.
- Debug Instrumentation Log Window -- dynamically monitor debug instrumentation output as your program runs.
- Debug Instrumentation Monitoring using an External Program -- monitoring debug instrumentation with an external program (Terminal.app, BBEdit.app).
- Debug Instrumentation Text File -- configuring and accessing the debug instrumentation log (text) file.
- info("runningunderterminal") -- returns the name of the terminal program if Panorama was launched under one, otherwise it returns empty text.
- labelizepattern( -- formats a text value using a label and a pattern.
- Recording Code Triggers in Debug Instrumentation -- the code triggers option automatically tracks whenever any code is triggered, whether from a menu, a button, or implicitly (for example when data is entered).
- Recording Control Flow in Debug Instrumentation -- configure debug instrumentation to automatically log when control flow is non-linear, for example a call, return, goto, etc.
- setzlog -- turns instrumentation coverage on or off for a specific procedure (or all procedures within a database).
- stdout -- sends one or more characters to standard output.
- zlog -- outputs a message to the instrumentation log (if instrumentation is enabled).
- zlogalways -- unconditionally outputs a message to the instrumentation log.
- zlogcoverage -- allows instrumentation coverage to be turned on or off within a procedure.
- zlogdictionary -- outputs a data dictionary to the instrumentation log (if instrumentation is enabled).
- zlogging( -- returns true if zlogging is enabled for the current database and procedure, otherwise false.
