A text constant (see Constants) is a series of characters surrounded by quotes. When writing a text constant you may choose from six different types of quotes: Double Quotes, Single Quotes, Curly Braces, Smart Double Quotes, Smart Single Quotes, and Pipes.
Double Quotes — This is the most common quoting method. The embedded text begins with a " and ends with another ".
"January"
A possible complication is if you want to include the " character itself in the embedded text.
Suppose that you needed to use the text The shim was 6" high in a formula. Using double quotes around the constant will cause a grammar error, because Panorama will think that the embedded text ends after the second " character, and it won’t know what to do with the text high".
"The shim was 6" high"
One solution is put two double quotes in a row . Panorama will convert these into a single quote and continue with the text constant.
"The shim was 6"" high"
Another solution is to use a different type of quote (see below).
Some other programming languages solve this problem by using an escape character, usually a backslash. Panorama does not use escape characters in text constants.
Single Quote — The embedded text begins with a ' and ends with another ', like this.
'Tuesday'
You can use single quotes if you want to include a double quote in the embedded text.
'The shim was 6" high'
Curly Brace — The embedded text begins with a { and ends with }, like this.
{San Francisco}
Smart Double Quote — The embedded text begins with a “ and ends with ”, like this.
“Gothic”
Smart Single Quote — The embedded text begins with a ‘ and ends with ’, like this.
‘Bohemian’
Pipes — The embedded text begins with one or more pipe symbols | and ends with the same number of pipe symbols. For example, if the constant begins with ||| then it must end with |||, if it begins with ||||| it must end with |||||. Using the multiple pipes as quotes makes it easy to embed any other kind of character in the text constant:
|||last="Elliot" first="Suzette" address="892 Melody Lane"|||
You can even embed pipes within a piped constant, like this:
|||| language=javascript code=||alert("Hello World");|| ||||
As you can see pipe delimited constants are very handy for creating text constants that contain computer code.
- Arithmetic Formulas -- mathematical operators and functions.
- Characters and Unicode Values -- working with individual characters of text.
- Constants -- values embedded into a formula.
- Date Arithmetic Formulas -- performing calculations on dates, and converting between dates and text.
- Formula Workshop -- formula workshop wizard for testing and experimenting with formulas.
- formulafields( -- returns a list of fields used in a formula.
- formulaidentfiers( -- returns a list of identifiers (fields and variables) used in a formula.
- Formulas -- basics of formulas: components and grammar.
- formulavariables( -- returns a list of variables used in a formula.
- Functions -- index of all functions available for use in Panorama formulas.
- Linking with Another Database -- techniques for relating multiple database files so that they work together.
- Non Decimal Numbers -- working with numbers in alternative (non-decimal) bases, including binary, octal and hexadecimal.
- Numbers -- Working with numeric values in a formula, and converting between numbers and text.
- Operators -- index of all operators available for use in Panorama formulas.
- Recompiling Code -- recompiling code & formulas
- Statements -- index of all statements available for use in Panorama procedures.
- SuperDates -- date and time combined into a single value.
- Tag Parsing -- Panorama functions for working with text that contains data delimited by tags, including HTML.
- Text Formulas -- manipulating text with a formula (concatenation, extraction, rearranging, etc.)
- Time Arithmetic Formulas -- performing calculations on times, and converting between times and text.
- True/False Formulas -- logical boolean calculations.
- Using Fields in a Formula -- accessing database fields within a formula.
- Values -- the raw material that formulas work with -- numbers and text.
- Variables -- storing and retrieving individual items of data, not part of a database.
