- expandall -- The expandall statement reveals all collapsed detail records associated with the currently active summary record.
- reverseorder -- The reverseorder statement reverses the order of the records in the database.
- sortdown -- The sortdown statement sorts the database by the current field. The database is sorted in descending order (high to low).
- sortdownwithin -- The sortdownwithin statement sorts the database by the current field, leaving any previous sorts intact. The database is sorted in descending order (high to low).
- sortup -- The sortup statement sorts the database by the current field. The database is sorted in ascending order (low to high).
- sortupwithin -- The sortupwithin statement sorts the database by the current field, leaving any previous sorts intact. The database is sorted in ascending order (low to high).
