The info(“procedurelibraries”) function returns a carriage return separated array listing all of the custom statement libraries that are currently installed.
This function returns a carriage return separated array listing all of the custom statement libraries that are currently installed.
This example checks to make sure that the _SpeechLib library is loaded, then says hello if it is!
if arraycontains(info("procedurelibraries"),"_SpeechLib",cr())
speakwords "Hello"
speaknow
