The eulersconstant( function returns the value of Euler’s constant.
This function returns the value of Euler’s constant (expressed in the maximum precision allowed for a floating point number in Panorama).
eulersconstant() ☞ 2.718282
You can also simply type in Euler’s constant using the Mac’s Character Viewer. To open the Character viewer choose Edit>Emoji & Symbols, then click on the Command icon in the upper right. Then look in the Math Symbols section.
ℇ ☞ 2.718282
See Apple Support Note HT201586 for more information about using the Character Viewer panel.
10.0 | New | New in this version |
