The emptylineitemnumber( function returns the numeric suffix of the first matching line item field that is empty (if any).
This function has one parameter:item – root name of the line item. May include or exclude a suffix of Ω, but should not include a numeric suffix.
This function returns the numeric suffix of the first matching line item field that is empty (if any). This example uses this function to fill the next empty line item in the current record with 1 Widget for $10.00.
let nextItemNumber = emptylineitemnumber("Qty")
set "Qty"+nextItemNumber,1
set "Item"+nextItemNumber,"Widget"
set "Price"+nextItemNumber,10.00
set "Amount"+nextItemNumber,10.00
A related feature is the emptyfield statement, which makes the next empty line item the active field.
